Results 1 to 9 of 9
  1. I really need empty DVD covers for my homemade VCDs.... Just to give it that extra look of proffesionality, and because I like to see the movies standing on my shelf....
    Please help me if you know of a place (preferably at the internet) that sells empty DVD covers...
  2. email me....i sell amaray replacement cases in lots of 10 from time to time($5.50 + $2.50 shipping)
  3. Or better yet, go on EBay and do a search for "amaray dvd" and you'll find a guy who sells tons of empty DVD cases. The best part is he sells double sided DVD cases also! I recently bought 200 empty double sided DVD cases (to hold 400 VCDs), and the total price on it was $40 + $35 S/H. Honestly, it sounds expensive but it's really not. Plus I print my labels for each CD, and I print inserts for the DVD cases... so the whole thing looks extremely professional.
  4. You could also go to your local video store. Most cases on the shelfs are empty! ;-)
  5. In norway, you can buy them at "Europris".
  6. Member zzyzzx's Avatar
    Baltimore, MD USA
    If you just need a few then reuse some of those AOL cases you keep on getting.
    Feb 2001
    Palmdale, CA
    At computer shows they run about .50 - .70 a case.
  8. I went to CompUSA and they were giving out the AOL cases... so I grabbed 10. Went back later, none left... and I haven't seen them anywhere ever since. The major problem with them is AOL puts stickers all over them, makes them sticky, sometimes they don't peel right. Regardless, I find it easier to just buy them in bulk and hide them in my closet.
