i have backed up a ton of my movies in the avi file type since they take up less than a gig of space, but when i play them the quality is only decent, especially the darker tones (dark grays, dark browns, and blacks), they turn out very pixilated, but when i convert them to dvd to burn them, the quality is fine from the disc.
so i recently ordered a dvi to hdmi cable so i can save the discs, sharpie ink, and dvd cover paper, and just play movies on my tv via my computer, but my question is, if they look that bad on a 19" monitor, i cant even imagine how bad theyll turn out on a 60" hdtv. so what file type should i convert them to to make them play as good as when they are on a disc? (without taking up the 4GB).
thanks for all the help.
Buy a new 1TB HDD and keep the DVDs in original quality.
Have not mentioned method used or compression .in the avi file type since they take up less than a gig of space
You might want to try avidemux .
Audio :
Set default audio if multiples are detected
Compression to mp3
Filters > change to stereo , 41,000mhz
bitrate > 56
Then do video
Compressor = x264
Filters = Crop black + resize
Use calc to calculate video bitrate for file size max output, hit apply
Compressor > pass type > change if required
(video setup is done after audio setup because it has an effect on video bitrate calculated)
Save as avi (add avi extension) , and wait till completed
In avidemux settings , you can disable multi threading support for x264 , to prevent 100% cpu usage on both cores in a dual core setup, dosent really improve speed of conversion process .
In comparing against xvid , x264 wins with less macro block appearance
Need to supply "File Type" and "Mime Type" info for MKV file
By oneking in forum Newbie / General discussionsReplies: 9Last Post: 9th Feb 2012, 03:31 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 15:59 -
MPEG Layer 2 video file, is it an editor friendly file type?
By ferran275 in forum Video ConversionReplies: 18Last Post: 16th Apr 2010, 23:41 -
Audio files now show as "Winamp Media File" in file type
By tmh in forum AudioReplies: 3Last Post: 7th Jan 2008, 13:25 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 11:39
