    Feb 2008
    Philippines
    hello! newbie here. can anyone help me in extracting the audio clip from a submenu? it's actually quite short just about 20 seconds but i have no idea how to grab it. i tried converting all the audio using imtoo dvd audio ripper but i can't find the track or clip i was looking for. I tried using Pgcedit as well it's just a little too much technical for me. I seem to be able to trace the "VTSM" and when i display or run it, i do see the menu i was looking for but i can't seem to trace where it links to the audio part.
    help please!!!!
  2. Hi-
    I'll assume the DVD is on the hard drive since you were fooling around in PGCEdit. Open the IFO containing that menu in PGCDemux, tick "Menus" under Domain rather than the default "Titles". Use the drop-down box to find the menu you want, give it an Output Folder and Demux. You'll get the audio by default. If you also want the motion or still menu video, also tick the "Demux Video Stream" box.
    Feb 2008
    Philippines
    sorry if this sounds dumb but how do i know which IFO it is? is that the same as the VTSM i discovered?
  4. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    It should be the ifo for VTS# where that menu resides, e.g. VTS_01_0.IFO for VTS_01_0.VOB menu file of VTS1 or VIDEO_TS.IFO in case of VM menu (VIDEO_TS.VOB).
