Hi all, I use premiere noise reduction filter that took almost 4 days to encode 110 minutes. I cut it into several clips just in case anything happen with electricity then I don't have to start from the beginning. Anyway I use TMPGenc DVD Author 3.x to author DVD but I noticed that in every transition of m2v file I see a time gap (when I played it in my home DVD). It is not much but still annoys me after I spend so many time to encode it.
I do research and seems that it is preferable to make DVD from just 1 m2v file to avoid this. Is there anyway to join all the m2v easily? Does m2v can be join without re-encoding like VOB? I use CBR and all clips have same bitrate (9000kbps).
I am not worry with audio because I can just encode it again using the whole movie. Thanks for the advice guys.
				Results 1 to 11 of 11
	COPY /B VIDEO1.M2V + VIDEO2.M2V JOINED.M2V
 Isn't MS-DOS a powerful OS ? who needs XP and the stupid Vista ?
	Well I know it works with VOB. Does it work with m2v as well? I will try it, thanks!
	That is not a good way to do it. That'd be like glueing the back of one book to the cover of the 2nd volume, and say it's one book.Originally Posted by Delta2
 mpg has headers, and if you just string them together with copy, you'll get headers and stuff in the middle of the resulting "mpg". Only headerless formats (AC3 is one such) can be concatenated with DOS copy.
 No, use a real mpg editor to concatenate them.
 However, TDA should create a seamless join, if you remove the chapter point TDA inserts at the join. Some players are reported to show a slight pause anyway, but on my players, as long as I add all mpg files to the same track/title, and remember to remove the chapter point, the track plays without any pausing.
 /Mats
	 You could use DvdMaestro to authour your final dvd, it allows you to drop multiple .m2v files into the a single video timeline, then you can either drop your complete audio track into the audio timeline or Create A Sync Audio track from the several parts that match the video sections. You could use DvdMaestro to authour your final dvd, it allows you to drop multiple .m2v files into the a single video timeline, then you can either drop your complete audio track into the audio timeline or Create A Sync Audio track from the several parts that match the video sections.
 Maestro then joins everthing together into a seamless single VTS when it authours the Dvd.
	Well videoredo say can't work with elementary stream. Both copy /b and DGIndex combine the file but when I tried to author in TDA the later part seems have problem.
 I finally use tmpgenc express tool to make mpg file using copy /b files m2v and the audio mp2. Seems OK.
  Fastest & easiest way to convert files from dvd to upload to Youtube?By scarypoultry in forum Video Streaming DownloadingReplies: 2Last Post: 6th Jul 2010, 03:49
  Easiest, fastest way to convert MKV to Blu Ray with 1080p aspect ratioBy jfk8680 in forum Authoring (Blu-ray)Replies: 3Last Post: 13th Apr 2010, 00:07
  Easiest and fastest ripping prog?By Valioser in forum DVD RippingReplies: 1Last Post: 5th Mar 2009, 18:57
  Easiest and fastest way of converting MKV files to be played on HDD player!By kebabtomten in forum Video ConversionReplies: 2Last Post: 2nd Dec 2008, 22:33
  Easiest way to join several MP4 files?By slateef in forum EditingReplies: 1Last Post: 20th Sep 2008, 23:44
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
