Hi,
I am looking for a TS stream file analyzer.
I record movies on DVB-T and I process the TS streams with ProjectX. But I have problems getting the right subtitles colors and I would like to know what the original subtitles colors are coded in the DVB TS. How could I do this ? I tried TSReader but there is no user manual or help and I could not get through.
gabier
Use this one, as it doesn't really "require" Java. The runtimes are already built in, but it doesn't install that bloated java jre stuff. Try it, you'll like it!
http://download.videohelp.com/download/ProjectX_090.4.00.zip -
Ah, but it does - except its a virtual java engine - nifty. Pity it is so expensive
Though I still can't figure out how to extract the subtitles, oh well.
Thanks btw -
Hey,
It seems we got a little out of my subject. Maybe it was not very clear. My problem is not to demux the TS stream (ProjectX is ok for this job) but to visualize what is inside it (packets, tables and so on).
If I can't do that, I won't be able to understand why ProjectX get mixed with the colours of subtitles and to fix this puzzle.
Gabier
need MPEG2-PS stream analyzer/reader
By amitchawla in forum Video ConversionReplies: 0Last Post: 10th Jan 2012, 01:16 -
h264 analyzer
By ranmamez in forum Newbie / General discussionsReplies: 7Last Post: 22nd Apr 2011, 11:32 -
Elementary stream analyzer
By pijetro in forum Authoring (Blu-ray)Replies: 1Last Post: 24th Nov 2010, 20:38 -
DVB analyzer
By -Sandro- in forum Capturing and VCRReplies: 0Last Post: 11th Mar 2010, 18:53 -
Spectral Analyzer for Vegas 6.0?
By solarblast in forum AudioReplies: 4Last Post: 3rd Nov 2008, 08:54
