    Feb 2008
    I'm trying to use a jpeg for the background but for some reason its gets blown up to some crazy size.
    The image is super pixelated and all wont fit on the screen. This never happened in the previous version, you would just get the image and black borders if it was too small.
    Is there anyway to stop this or change the dimensions of the background image?
    Feb 2008
    Nobody familiar with this problem, or just no solution?
    If no one can answer this, can someone give me a good dvd menu making tool i can use with nero?
