Hello,
I know there are calibration discs out there, but I know nothing on
the subject and on my 46" Samsung HDTV The 3 different settings are sub par at best..
Does anybody know of any services that do the calibration. I live in West Virginia..
Thanks for any Help...
	I'll do it if you pay my expenses.
 Seriously, did you check the Yellow Pages?
 Good Luck!!!
	I had a local electronic firm calibrate my HDTV, but wish I won't have. When I contacted them, they wanted $350. I said, no, thats too much and asked if they would do it for $250. They said, yes, but it would be a one-time adjustment, meaning they would only make the initial changes. Well, it took about 2 hours. The HDTV looks OK and the Blu Ray player (PS3) plays Blu Ray movies OK, but the problem is when playing standard DVD movies, the dark scenes are almost black ! When they make the calibration, the adjust the grey scale tones, etc.
 So, now I wished I won't have done it. Fooie.Owner: Panasonic HDC-SD1 camcorder w/8gb SDHC card (AVCHD)
	check out the AVS FORUM they have threads on different SAMSUNG HD LCD TV's on how to calibrate to the best settings for HDMI, COMPONENT, PS3 & XBOX 360. then you can calibrate it yourself to your liking.Originally Posted by ofield1
 http://www.avsforum.com/avs-vb/forumdisplay.php?f=166
	I'd still agree with Budz. On the AVSForums, you should be able to find some information in regards to your television.
 If you search on isf calibration you should see lots of hits. You'll see people on there recommending certain individuals. These people occasionaly do traveling calibration tours so you could see if one is coming near your location. You might even find some that have already had sets calibrated in your area and they might point you in the right direction.
 Hope this helps some.
	Hi,
 I use one of these http://www.colorvision.com/product-ht-stv.php
 you need to connect it to a pc but it works very well.
	I know this isn't the best way but on many Lucasflim and Pixar DVD's there are THX Optimizers that help you calibrate your tv,a better option is to buy DVE DVD:
 http://www.audioholics.com/tweaks/calibrate-your-system/digital-video-essentials-dve-review
  How to calibrate LCD color monitor ?By SingSing in forum Software PlayingReplies: 2Last Post: 8th Mar 2011, 11:24
  Do Samsung HDTV's have an RF antenna connector for receiving off-air HDTV?By pianopeddler in forum DVB / IPTVReplies: 2Last Post: 6th Aug 2008, 22:43
  Need al little help getting my new ati hdtv pci card to sense HDTV channelsBy MidnightMike in forum ComputerReplies: 8Last Post: 23rd Jul 2008, 03:12
  Problems with connection with my Panasonic HDTV and Timewaner HDTV box...By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 23:39
  Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 01:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
