  1. Hey guys
    I was wondering if someone could tell me the default factory video settings for a dvd. I think its in Kbps. I also would like to know if there a program out there to verify that info ...
    Thank
  2. Hi-
    If you're referring to bitrate, there are no default factory settings. Each DVD video will be encoded differently. If you'd like to find the bitrate of a retail DVD, put it in your DVD-ROM and run DVD BitRate Viewer on it.
  3. Thanks for the reply
    Is there any benchmarks, minimum or maximum?
    May 2007
    reality
    To the left click on "What Is DVD". There is a technical section describing DVD.
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Most DVD authoring programs default to ~4000-6000 Kb/s ave. VBR at 720x480.
    Higher quality takes you up to >8000Kb/s. 352x480 can get by with 3000-4000 Kb/s.
    Commercial DVD authoring can lower bit rate through various techniques. Most important is starting with a high quality source and managing pixel motion.
    http://www.kiva.org/about
