Hi,
I currently rip/burn DVDs to/from .ISOs using DVD Shrink 3.2 and ImgBurn, respectively, but would like to rip to VIDEO_TS/AUDIO_TS folders so I can also view the films on my P.C.
I managed to do this once, a few days ago, using, I'm convinced, a guide I found here, but, for the life of me, I can't seem to find the guide again.
Sorry if this is a pretty dumb question.
Thanks for any help anyone can give.
https://www.videohelp.com/guides/how-to-rip-a-dvd-to-the-hard-disk-using-dvdfab-hd-decr...er-id1052#1052 (It's even on the front page)
You could also play dvd shrink isos directly using VLC Media Player. -
Thanks.
I didn't realise you could play ISOs.
The guide I used, previously, was for ripping DVDs to VIDEO_TS... folders using DVD Decrypter. Maybe DVDFab HD Decrypter is just as good, but I know there's a DVD Decrypter guide around somewhere.
Thanks, again. -
Greets,
DVDShrink allows you save to Hard Disk Folder as well as ISO. The hard disc folder option is the Video_TS format that you seek. You can also use Daemon Tools to mount the iso and view that way with your software dvd player as well.
Cheers,
Rick -
DVDFab HD Decrypter is very simple and it supports newer dvds with new copy protection that dvd decrypter doesn't support.Originally Posted by Crimea
Thanks, Baldrick, also.
I'll give DVDFab HD Decrypter a go.
Ta.
AVI to DVD -didn't get video_ts or audio_ts
By Ursula514 in forum ffmpegX general discussionReplies: 5Last Post: 8th Jan 2011, 14:31 -
Duplicate a DVD....can you simply copy Audio_TS folder and Video_TS folders
By True Colors in forum Authoring (DVD)Replies: 6Last Post: 29th Apr 2010, 14:37 -
I don't get any movie.DVD folder (audio_TS & video_TS), help!!!
By dbedolla in forum MacReplies: 1Last Post: 10th Nov 2009, 03:21 -
Copying a Recorded DVD--Video_TS and Audio_TS
By solarblast in forum DVD RippingReplies: 14Last Post: 23rd Jan 2009, 07:41 -
AVI to DVD not outputting Video_TS or Audio_TS folders
By threesixes in forum ffmpegX general discussionReplies: 18Last Post: 30th Dec 2008, 01:23
