I have an Imation External Burner that will no longer burn dvd,'s. It reads ok. Can anyone help on what maybe the problem
Aside from the fact this is not a restoration question . . . . . .
There are separate lasers for reading and burning. Chances are yours simply has died and will no longer burn. You could try cleaning the lens to see if it helps, but burners are now a commodity item. Use them until they break, then replace them. I suggest that it is not time for you to replace yours.
Might I also suggest you consider a better brand next time ?Read my blog here.
Imation 4x DVD-RW problem?
By carbfrze in forum MediaReplies: 8Last Post: 11th Mar 2009, 15:31 -
Question on readability of Imation DVD-R 16X
By Dofod in forum DVD & Blu-ray RecordersReplies: 2Last Post: 22nd Dec 2008, 12:14 -
TDK now Imation - updated 10-30
By BiggerJim in forum MediaReplies: 1Last Post: 29th Oct 2008, 16:21 -
Imation: Worst DVD Brand
By J C in forum MediaReplies: 4Last Post: 5th Nov 2007, 18:46 -
Imation DVD Writer problem?
By MAAG in forum DVD & Blu-ray WritersReplies: 3Last Post: 18th Jul 2007, 12:41
