Ok. I've got one that I have't ben able to find a proper solution via google.
After creating an FLV video, I suddenly realized that I left out the audio. (I turn down the
audio when I'm creating videos that I'm testing for visual imperfections, etc)
So, now my flv has no audio and I want to mux the track from my AC3->wav on my other
computer into this one on this computer![]()
Because the audio in question has a dealy of 1200ms, that creates a problem with muxing
it into the flv. So, to be sure, I loaded the orginal video back into virtualdub and imported
the .wav file and set the interlace (delay) to 1200ms, and the short video plays in sync
perfectly.
Now I want to re-encode this using my usualy ffmpeg front end tool, but I don't know how
to set it up to include the delay.
Note, I found this on google, but its too confusing to figure out:
--> http://howto-pages.org/ffmpeg/#delay
DELAYING THE AUDIO OR THE VIDEO
Depending on how your original files were generated, it could happen that the sound and the picture become out of sync when you start processing them with ffmpeg. Thankfully, there's a mechanism that will allow you to stagger the audio and video with respect to each other in the output, thus bringing them back into alignment
- the "-itsoffset" option, which is used this way:
$ ffmpeg -i input_1 -itsoffset 00:00:03.5 -i input_2
Thanks for any input,
-vhelp 4546
(Audio Delay Issue and remuxing: Partially RESOLVED)
Ok. I had enough
After countless trial n error I could not obtain the answer using ffmpeg
and using the above methods, plus other ideas found via google. It could have been the build
that I was using -- there are many. Anyway.
Although I was hoping to use ffmpeg and a one-click solution method to my tool to do this step,
I resorted to using virtualdubmod and then adding the 1200ms delay and recreating a new avi,
instead, and then re-encoding a new flv video. I guess there are some things you can't do in
certain tools. oh well.
In case others are following..
Although the audio delay issue was resolve through the usage of virtualdubmod, at this time,
ffmpeg was not up to the mission.. it failed.
-vhelp 4547
HowTo add permanent Letterboxed subtitles to video w/ Virtualdub, SRTtoSSA
By KneeRow in forum SubtitleReplies: 20Last Post: 13th Feb 2013, 13:05 -
Need help to find the perfect encoding string for ffmpeg
By iwiiiiiiiiii in forum LinuxReplies: 1Last Post: 14th Oct 2011, 14:28 -
mp4muxer: does it have command line param string output somewhere ?
By vhelp in forum Video ConversionReplies: 3Last Post: 23rd May 2010, 20:56 -
Howto add subtitles to episodes DVD?
By RG80 in forum SubtitleReplies: 0Last Post: 28th May 2008, 14:48 -
HowTo Capture DV, Denoise, Add FilmLook and Convert to DivX
By jvanbarel in forum User guidesReplies: 0Last Post: 6th Nov 2007, 07:59
