Plasma Display PDP-434CMX with Video Card PDA-5004 bought in the US end of 2004, so far used with YUV cable, now connected new Panasonic DVD player SD with HDMI output (DVD-S100EG-S) to the Plasma input 2, DVI-D but no signal??? The input 2 / DVI-D does not support HDCP, but when the DVD-player play's a regular DVD and just upscales the signal, I am sure there is no HDCP activ???
Thanks jagabo! I will check it out with Panasonic and let you know! I assumed that HDCP (high def content protections) is only activ if a HD signal is detected...but that might be wrong...to bad!Originally Posted by jagabo
Panasonic DVD & USB & SD Card Slot Problem
By Tim Sage in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2011, 19:23 -
Looking at a Panasonic NeoPDP Plasma - can anyone help?
By Jake Reacher in forum DVB / IPTVReplies: 3Last Post: 6th Aug 2010, 09:52 -
AVCHD SD CARD on Panasonic Plasma TH-P42G10A ???
By draven1968 in forum DVB / IPTVReplies: 0Last Post: 15th Jul 2009, 01:00 -
Zonefree DVD player into Panasonic Plasma not working
By Mark_MB750M in forum DVB / IPTVReplies: 11Last Post: 1st Sep 2008, 06:19 -
Widescreen playback on Panasonic plasma
By ozkelron in forum Software PlayingReplies: 7Last Post: 12th Feb 2008, 17:26
