I read in another forum that the reason that my video kept losing sync with the subtitles in Subtitle Workshop was because you need an avi with I-frames only to use when synching subtitles with this program. I was able to make one with Divx in Virtualdub for my first project that worked fine but when I went into Virtualdub this time to do another, I found the option grayed out in Divx. Does anyone know why? I was not using the DivxPro trial at the time so I don't know why this option might have been open at one time and then no longer available. Does anyone know how to access it or how to encode an avi with I-frames only with the x264 codec in Virutaldub?
Well, I keep losing sync when I move back and forth in the .mpg version. I don't know why DivX no longer allows me to adjust the keyframe interval and Cinepak seems to be the only one that allows it but that takes forever to compress.
I agree it's not true. But you can set the keyframe interval with Xvid. Or you can use an all-keyframe codec like DV (cedocida is a good DV codec). Or simply use uncompressed or lossless codecs like HuffYUV or Lagarith.
And regarding Divx: When using Presets you can't change the keyframe interval. Maybe you need to re-enter your registration code so you can turn off Presets.
How do I create a continous MPEG2 file from a DVD with video from menus
By porchmonkey in forum Authoring (DVD)Replies: 3Last Post: 5th May 2009, 05:48 -
MKV to MPEG2 - Not dropping frames, but not smooth - think it's audio
By Shade00 in forum Video ConversionReplies: 11Last Post: 18th Feb 2008, 13:20 -
Create one image from overlaying several frames?
By sincostan in forum Newbie / General discussionsReplies: 15Last Post: 15th Oct 2007, 11:07 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
how can I create mpeg2-TS clip composed of one (only one!!!) black frame?
By mb508 in forum EditingReplies: 3Last Post: 4th Jul 2007, 15:04
