Hi all, i am relatively new to this forum, please pardon me for any reposts.
i have a dvd which i want to extract and reuse the starting video, continued by the moving video with the DVD menu infront of it. then editing the thumbnails for each episode to other pictures.
then i would like to convert several AVI files to dvd-video playable format that are linked to each different thumbnails.
how do i go about that? please advise, thanks !
Hi-
My advice is "don't". You're biting off more than you can chew. However, getting just the menus is fairly easy. Open the complete DVD in VobBlanker, blank out all the PGCs (except for the opening video you said you want to keep), and then process it. That will leave you with just the opening video, the menus, and a bunch of empty PGCs. You can then replace those empty PGCs later on with the videos you plan on converting from AVI. But that part can be pretty difficult.how do i go about that?
My suggestion is to extract the opening video and the video portion of the menus (stills or moving video), edit them to replace the thumbnails if you like (even that's pretty tricky unless you've had a lot of video encoding experience) and then use them in an authoring program, freeware (like DVDAuthorGUI or GUIForDVDAuthor) or commercial (DVDLab or TDA), when you're creating fresh menus. I have a guide about extracting and replacing edited menus which you may find somewhat useful, but it doesn't really address what you want to do:
https://forum.videohelp.com/topic313743.html#1606732 -
hi, thanks for your advice, will follow your tutorial and try to go about it. had a little experience on encoding, hope to gain more from this. =)
Extracting menu buttons
By headless chicken in forum MacReplies: 0Last Post: 2nd Apr 2012, 23:54 -
Extracting and editing an existing DVD menu
By sambat in forum Authoring (DVD)Replies: 18Last Post: 21st Mar 2010, 17:23 -
Extracting parts of a DVD
By jabbo5150 in forum MacReplies: 9Last Post: 31st May 2009, 23:50 -
Extracting subtitle from DVD
By gameroftheuk in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2008, 16:09 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
