Hi,
I am using Windows Vista.
I am using ImgBurn. First time I am trying to write one 7.25GB DVD to two 4.70GB DVDs. I have copied the image
og 7.25GB DVD to my hard drive. It has created one ISO and one MDS file.
Now I have inserted one 4.70GB DVD and select source of MDS file and destination is my 4.70GB DVD. When I press to start writting it is prompting me error that the destination drive has not enough space to burn. Still I press
"Yes" then it is giving me one error and stopped.
Is there any idea, how I can burn 7.25GB DVD to two 4.70GB DVDs?
Thanks,
If it's a DVD-Video then split it with DVD-Shrink or DVDfab, see https://www.videohelp.com/guides?searchtext=&tools=&madeby=&formatconversionselect=DVD9...or+List+Guides
You can use DVDFab Platinum and retain menus on both disc's while splitting it across two disc's & you can also use DvdReMake Pro to do the same thing.
DvdReMake Pro is a little more complex to use but it's nice because you can delete the buttons to the itmes you deleted from each disc when splitting.
I've used both several times for this.
How much video on 25gb disk?
By archp2011 in forum Authoring (Blu-ray)Replies: 6Last Post: 15th Jun 2011, 07:15 -
MultiAVCHD mkv to 25gb bdr
By VOYAGER2009 in forum Authoring (Blu-ray)Replies: 4Last Post: 25th Apr 2011, 09:37 -
Split bd 50 into 2 25gb disks
By fremat in forum Blu-ray RippingReplies: 1Last Post: 23rd Oct 2009, 10:04 -
windows live 25GB storage
By victoriabears in forum ComputerReplies: 6Last Post: 19th Feb 2009, 20:30 -
backinig up dual layer bd to 25gb bd-r
By lbbruiser2 in forum Blu-ray RippingReplies: 17Last Post: 5th Jan 2009, 03:03
