  1. Basically what I am trying to do is copy 3 epidodes to VCD and be able to start them using a working menu.
    Currently I am able to make a VCD with a nice menu with pictures taken from the episodes but the menu is not clickable. Perhaps I am doing something stupid but I cannot see how to create a working menu. The VCD I manage to make lists each episode as a chapter - is this supposed to be the case? And the only way to access them is to select the relevant chapter.
    On another point, is there a way I can copy a seperate "opening credits" file to the VCD but set it up so that it runs immediately before each episode plays, or am I better off joining it to each episode?
  2. VCD menues are not clickable. You're not doing anything wrong.
    If you were using EZ CD Creator you could add the opening credits mpeg you desire, but with Nero the effect you are looking for isn't possible without adding the credits to the main mpeg.
