i am unable to view the files on many DVDs.I have a Sony DVD drive they are perfectly fine and play on my DVD player and also on the dvd playing soft on my comp but it dosnt show up in 'my computer'. it just shows as CD drive and if i open it it shows it as empty. the videos play perfectly fine. i wanna copy it to my comp. pls help!
Thnx
yes it is burned on my comp. but its in good condition and works on a regular dvd player.
Reboot your computer (without the DVD in the drive). Hold down a shift key while you insert the DVD. Keep holding the shift key down until the drive stops spinning. Go to explorer and open the drive.
This procedure will prevent any software from autoloading when you insert the DVD.
IE8 - unable to view drop down lists. Help!!
By thegeeman in forum ComputerReplies: 4Last Post: 18th Aug 2010, 11:01 -
Unable to view streaming URL in full screen theater mode Adobe 10
By badger1194 in forum Video Streaming DownloadingReplies: 1Last Post: 5th Aug 2010, 22:12 -
AVC: Unable to view the Video in sync with Audio
By bulava in forum Software PlayingReplies: 6Last Post: 19th Jun 2010, 23:15 -
unable to view live webcasts?
By Mr anderson in forum Video Streaming DownloadingReplies: 2Last Post: 24th Feb 2009, 12:31 -
Unable to burn DVD, unable to access the Video_TS.ifo.
By Asymmetry in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2008, 00:02
