I have a High School Musical I'm recording for the School..... and I want to capture the audio directly off the soundboard digitally...... and I want to use my laptop.
On the soundboard = left+right RCA output jacks
On my laptop = 1/8th inch MIC input jack
If I use AUDICITY and a RCA to 1/8th headphone cable (from RadioShack).......will this worK? Or do you have a better idea?
I have not tested what I think might work but wanted everyone's opinion if I'm going down the right road.
Please help....
Should work, yes, but it won't be a digital connection between mixer and laptop.
/Mats -
the School's soundboard only has RCA audio outputs....but its good enough to capture clear voices off the mic'ed actors in the MusicalOriginally Posted by mats.hogberg
It may work, but the quality will not be good for a couple of reasons. First, the output level of the sound board is line level; the input level of the mic input is mic level. You may be able to adjust the output and input levels such that they don't distort, but that is not always true.
Second, the mic preamps (input) on a computer sound card are the worst possible way that you can record audio. The noise and distortion are terrible. These inputs are designed for communications, not music. Are you absolutely sure that there is not an auxillary input on the computer? If there is, the RCA-to-miniplug adapter is just the ticket.
There are external audio input interfaces available that bring the audio in on the USB port, and they are not expensive. I have the Griffin iMic, which does a decent job for a non-critical application. Someone in your school will probably loan you one if you don't want to buy one.
After all this, you may be perfectly fine with the quality you get using the mic input, but you're not going to win any Grammy Engineering Awards!
Audacity will work with the cheapest to the most expensive sound capture devices.
Capturing DV camcorder to laptop w/o firewire port
By fvisagie in forum Capturing and VCRReplies: 33Last Post: 17th May 2012, 14:14 -
Capturing in Premiere on a brand new laptop.
By havash in forum EditingReplies: 30Last Post: 31st Jan 2010, 15:37 -
mini dv capturing on laptop without firewire?
By the1st in forum Capturing and VCRReplies: 2Last Post: 9th May 2008, 11:23 -
Capturing HD (1080i) in Europe to laptop
By hhhgamewmx7 in forum DVB / IPTVReplies: 3Last Post: 2nd Dec 2007, 06:37 -
Capturing xbox 360 onto Laptop
By jase1332 in forum Capturing and VCRReplies: 1Last Post: 12th Aug 2007, 07:24
