hey guys,
im new in xvid compression in virtual dub
anyone how to set the video in max bitrate of 8mbps and up,with resolution of vga(640x480)
so that my mini dv videos will captures at high compression.
pls explain in specific details or with scan the better..tnx in advance more power
8mbps (8000kbps) would be way too much for Xvid. Easier would be to set the Target Quantizer to 2 or even 1 if you want to max out the codec.
If you are looking for the settings: 'Video>Compression>Xvid MPEG-4 Codec>Configure>Single Pass'. Click on 'Target Bitrate' and it will Change to 'Target Quantizer'. Then adjust the quality.
how to set max bitrate in dvd architect
By ejparle in forum Authoring (DVD)Replies: 1Last Post: 19th Feb 2011, 17:44 -
virtual dub não abre arquivos cokm codec xvid
By sandroguchilo in forum AudioReplies: 3Last Post: 14th Dec 2010, 17:43 -
virtual dub xvid codec encoding w/o profile
By caner12 in forum EditingReplies: 7Last Post: 5th Jul 2009, 13:08 -
xvid encoding in Virtual Dub, stats file?
By Xavier in forum Video ConversionReplies: 4Last Post: 10th Feb 2009, 09:46 -
Vegas, Xvid Encoding, Max Bitrate 56kbit only
By kidcash in forum AudioReplies: 3Last Post: 26th Dec 2007, 01:08
