I've read posts on this before, and whilst not exactly a newbie at authoring, I haven't a clue how to do this:
If I rip a DVD, I get VIDEO_TS and AUDIO_TS folders, these contain VOB files and I use a simple burning process to put them onto a DVD5. As I only ever use DVD5s, I sometimes use DVD Shrink beforehand also.
When dealing with an AVI, I have had to use ConvertX to DVD, with very disappointing results; the grainyness of the picture and colour distortion on dark backgrounds is abysmal. This is with all settings turned way up.
The effect is less pronounced when dealing with MKV files, but still a 4gb file becomes 2.2gb when Convert X to DVD reads the file; why is this? I've changed settings to allow for DVD9 (with the intention of simply using DVD Shrink afterwards) yet Convert X to DVD still only creates a 2.2gb VIDEO_TS file.
Is there any other programmes that will maintain the quality of a HD MKV video? Preferably a simple one, that deals with any muxing issues without giving me too many 'off the wall' options. I don't really want anything changed from the original file.
urb
Originally Posted by urb1972
does it have to be (1) TS file
I think your hitting a widow file size barrier, going to DVD you should be getting multiple VOBS at aprox (1) gig each, check your settings again
you don't want just (1) vob if your burning to DVD
and if your converting to 'transport streams' try setting for multple files, then use an editing program like avidemux2 or some other program to join them into (1) big TS file
BTW avidenmux2 will create mpeg-TS files if thats what you want , its in the output format selections menu , 3rd button /box, down, on the left of the program window
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
how to join mkv.a and mkv.b files
By sumeshkri in forum EditingReplies: 1Last Post: 5th Apr 2012, 19:56 -
Stripping sections of MKV files to seperate smaller MKV files
By spudz72 in forum EditingReplies: 6Last Post: 29th Jul 2010, 01:53 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 00:45
