My TV Card is Asus (s) M-1 and have this inputs
i connect my cable tv recevier to tv card with s-video out to s-video in and i use Power Cinema software and this is what i get when i play channel see video
http://www.youtube.com/watch?v=7KepuXOVjBI
Do anyone know how to fix it tnx in advance.
I'm assuming the S-Video from the box works on a TV or other device using the same S-Video cable? I'm wondering if it's a cable problem or a cable box problem?
If it does, do you have any other capture program you can try with the card?
I'm not able to identify that card. Have you looked in our capture card listing to the left under 'Asus' to see if it's listed there?
Assuming it's a PCI card, you might try it in a different PCI slot, also make sure it is seated properly in the slot. Also try updating the drivers from the Asus site. Or at least deleting the driver and re-installing it.
And welcome to our forums.
it works.Originally Posted by redwudz
I try with Power Cinema,Chris TV,iuVCR,ShowShifter and same happens.Originally Posted by redwudz
I don't know excatly how it's named because i lost tv card box but on tv card write Asus(s) M-1 E1 53302Originally Posted by redwudz
I think that is not to a slot or driver because tv card works when i try with antenna that only have my country channels.Originally Posted by redwudz
Thank you.Originally Posted by redwudz
problem connecting computer to telly using vga cable
By xtube in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2010, 04:01 -
Connecting a TV, cable box, and VCR/DVD
By jmarsico in forum Newbie / General discussionsReplies: 11Last Post: 31st Jul 2010, 20:31 -
HELP! Connecting cable box to computer for HD Recording
By wickedwheels in forum DVB / IPTVReplies: 16Last Post: 29th Aug 2009, 22:25 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Connecting subwoofer to amp - quick cable question
By heyjjjaded in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2008, 15:04
