Scope:
I have two files of different format. The first one is wmv and the second one is mp4. All I need to do is to merge these files and then convert them to 3gp.
This should be done in linux command string.
I use ffmpeg software for this.
What I've already done:
At first step I tried to convert both files to 3gp with success.
Then I tried to convert both to avi and then merge.
I use the following command lines:
After this I've merged video file where the first part is ok, but in the second one I've awful sound.Code:ffmpeg -i input.mp4 -f avi -s 352x288 -b 200 -r 25 - > temp.avi ffmpeg -i promo.wmv -f avi -s 352x288 -b 200 -r 25 - >> temp.avi ffmpeg -i temp.avi -acodec libamr_nb -s 352x288 -ar 8000 -b 120000 -vcodec h263 -ab 10.2k -ac 1 output.3gp
The problem is not in the exact solution. I need to merge mov and flv, mp4 and 3pg, etc.
The question is how I should do this correctly. Probably I need to convert both video to some kind of raw data file with some format (also may be I need to set the same bitrate, framerate, etc). After this I'll be able to merge the files and then convert to format I need.
So the problem is more theoretical then practical.
Any help is appreciated!
Thanks.
Finally I've the following lines:
This works fine.Code:ffmpeg -i promo.mov -f avi -s 352x288 -r 29.97 -ar 44100 -b 120000 -ab 64k -ac 1 - > temp.avi ffmpeg -i input.mp4 -f avi -s 352x288 -r 29.97 -ar 44100 -b 120000 -ab 64k -ac 1 - >> temp.avi ffmpeg -i promo.wmv -f avi -s 352x288 -r 29.97 -ar 44100 -b 120000 -ab 64k -ac 1 - >> temp.avi ffmpeg -i temp.avi -f avi merged.avi ffmpeg -i merged.avi -vhook '/usr/local/lib/vhook/imlib2.so -x 0 -y 0 -i watermark.png' merged-watermark.avi ffmpeg -i merged-watermark.avi -acodec libamr_nb -s 352x288 -ar 8000 -b 120000 -vcodec h263 -ab 10.2k -ac 1 output.3gp
How to join multiple youtube videos ?
By skorpinok in forum EditingReplies: 1Last Post: 13th Jul 2011, 22:42 -
what is the correct way to join videos in avidemux?
By sgbd in forum Video ConversionReplies: 4Last Post: 3rd Sep 2010, 09:03 -
How can I join my H264 videos?
By Daninet in forum EditingReplies: 8Last Post: 17th Jun 2010, 15:44 -
How to join two videos in the same window?
By bgeorgalas in forum EditingReplies: 5Last Post: 23rd Jun 2009, 06:49 -
I Can't Join 2 XviD Videos together!
By Nitro89 in forum EditingReplies: 10Last Post: 26th Jun 2007, 15:08
