Hello everyone.
I'm encountering a problem I've never had before. I recently purchased a set of MASK animated DVD's. I would like to rip them to watch downstairs through my Windows Home Server and other portable devices. These are legit purchased DVD's not video recorded bootlegs.
There are 4 discs, and each disk gives me an error when trying to read VTS_01_4.VOB. It's the same on EVERY disk. Every other .VOB rips fine. I've re-booted my machine, AND tried to rip the discs on other computers with the same problem.
I've tried ISO buster, DVD Decrypter, DVD shrink, DVDFabDecrypter - all of them. Tried to get the VIDEO_TS file, tried to write an .iso - nothing. ISO buster says "Following files are located on locations that are unreadable."
This is really strange.
Is this some sort of strange copy protection? I'm not trying to make copies, I just want the files to sit on my HDD so I can watch them downstairs.
Any thoughts here? Thanks!
I guess you used latest dvdfabdecrypter? You could also try latest anydvd(trial available). If they wont work maybe try copy on another computer/dvd drive.
Yhe Mask cartoons are difficult to rip, I have tried them years ago, something strange and not compliant with DVD standards, will not play on some DVD players, so I tried to rip them myself, to play on my portable several years ago.
I had no luck, this one of the very few DVD I have that I could not make into MP4 for my OPPO player from China. -
Well I've tried the latest DVDfabdecrypter, anydvd, and IMGburn. All have the same error at the same spot (48% into the disc, at VTS_01_4.VOB)
I've tried on 2 computers as well. Same problem. What could be causing this? -
If the errors occur at the same spot then the disc is probably scratched. This is why I have many dvd burners/dvd-roms to chose from because eventually one of them will be able to read a disc that is scratched.Originally Posted by Corellian Corvette
can you actually play the disc without any problems? If you try and play the dvd and it skips/stops or has errors at some point. It is possible that your set is defective.
I have played a couple of min of each chapter on the disc w/o problems. There are no scratches that I can see - the discs are brand new and practically flawless. I'll try again on my laptop and see if that helps at all.
Tthats your problem. You have to play the whole disc, or if you know what files on the dvd are in the VTS_01_4.VOB, skip to those eps and see if they play all the way through.
I/O errors using ImgBurn and DVD Decrypter
By jcsdmd in forum Newbie / General discussionsReplies: 16Last Post: 27th Aug 2011, 15:58 -
Trying to extract VOB file with Isobuster, nothing happens?
By dai3504 in forum DVD RippingReplies: 2Last Post: 8th May 2011, 11:42 -
IsoBuster settings for read errors
By 1337assassin in forum Newbie / General discussionsReplies: 8Last Post: 23rd Oct 2010, 13:20 -
Strangest problem randonly occuring with downloaded FLV files
By apak in forum Newbie / General discussionsReplies: 1Last Post: 10th Sep 2010, 06:44 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02
