I am using DVDAuthorGUI to author a DVD. I have several TV shows on each DVD that vary in times, roughly about 45 minutes. There all not the same time. For example, one title is 45 min 6 seconds. Another is 45 min 37 sec. etc.
Okay, now I am adding chapter stops to each title so it looks like this:
00:00:00.00
00:09:00.00
00:18:00.00
00:27:00.00
00:36:00.00
00:45:00.00
The last stop ends at 45:00.00. I want to set the next chapter stop so it will return to the main menu.
Is there a special code or number I should add so that the next chapter stop will go back to the menu page. or do I have to time each individual episode so that it looks like this:
00:00:00.00
00:09:00.00
00:18:00.00
00:27:00.00
00:36:00.00
00:45:00.00
00:45:37.00
I guess my question is: How do I make the last chapter stop go back to the main menu? What number do I have to input so that when you press the skip button on the remote it will advance back to the menu.
Thank you!
It's been a while since I used this app., so I might be mistaken, but I believe the default is to return to the menu after playing an episode.
Get into the rather extensive preferences menu and check it out. I believe you can set it there to go on to the next episode or return to the menu. -
under 'nav commands', set each title to go back to the menu there. When you press 'next' on your DVD remote, it will return you to the menu.
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 12:30 -
Chapter screens for scene selection menu question?
By ecc in forum Authoring (DVD)Replies: 3Last Post: 17th Feb 2009, 14:49 -
question about how to add chapter points to already made DVD
By jimdagys in forum Authoring (DVD)Replies: 15Last Post: 24th Apr 2008, 14:44 -
DVD Chapter Question.
By firewaterjoyride in forum DVD RippingReplies: 2Last Post: 18th Aug 2007, 23:05 -
Chapter question
By BCbear in forum Authoring (DVD)Replies: 15Last Post: 30th Jun 2007, 08:52
