with what tool can i seperate audio and video from a mpeg1video file? i want to change the audio to ac3 and then multiplex. kindly adivce me what programme should i use to do this. first i want to seperate the audio from the video then to convert it to ac3 and then i want to join the audio with the video.
thanks in advance.
If you're trying to convert VCD to DVD, you can use SVCD2DVDMPG
There is a free older version.
This actually just converts the audio sampling rate from 44k to 48k, it remains MP2.
If you really want to convert to AC3, you can use any of a number of audio apps: BeSweet, FFMpeg, etc. -
i used svcd2dvd . loaded a file . source was a vcd file.iwanted to get the audio converted to 48 khz. but when the conversion was completed i got a video file only which is miv file. int he movie clip file i dont get anything it is zero bytes. no audio.where has the audio gone?i selected mpeg ps .
how to seperate audio from DAT file
By pcb in forum AudioReplies: 5Last Post: 4th Jul 2011, 14:51 -
Vegas 10: saving audio tracks to seperate .wav file
By Toastie in forum EditingReplies: 8Last Post: 6th Mar 2011, 21:50 -
Play Video and Audio seperate to see if in sync
By RickyPinxt in forum Authoring (DVD)Replies: 10Last Post: 12th Jun 2010, 10:35 -
Converting AVI to MPEG-2 with no seperate audio file
By Craig876 in forum Video ConversionReplies: 1Last Post: 9th Nov 2009, 17:38 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 11:12
