Recently my Sony DVD+-RW-Q58A stopped playing DVDs properly. Whenever I insert a NORMAL DVD the sound jumps and the picture does as well, however, burned DVDs still work just fine. I do a LOT of burning on this drive, and use ImageBurn, DVD Shrink, and DVDFab HD Decrypter (for more recent DVDs.) I'm not sure what prompted the problem, it just started out of nowhere. Any help on the subject is much appreciated.
would be helpful if you posted what dvd software you're using. powerdvd? vlc? realplayer? windows media player?
It could be scratches or fingerprints on the disc that is preventing normal playback? Have you looked at the disc to make sure that the bottom is clean and free of scratches?
Believing yourself to be secure only takes one cracker to dispel your belief. -
I use Dell Media Experience.
Even DVD's that are brand new (free of scratches and fingerprints) won't play. It's really odd that it will play all my burned DVDs but not any regular ones. I am just stumped here. -
Have you changed the region coding of the drive? Just a thought, but your burned discs are likely region free.
Google is your Friend -
SO, I got it and thought I would pass on the word..
Since my last post I realized that I could still burn dvds but at turtle speed.(still not watch regular ones) Then with some advice from another website, I checked my IDE channels and found that my secondary IDE channel was on PIO instead of DMA mode. I unistalled it and then rebooted and wabam!! it worked! Back to DMA mode and burning at regular speeds again
I'm glad you got it fixed, and you would have gotten the same advice here if we had known of the other symptoms.
DVD exploding inside the drive from a drive exceeding 24x. True?
By snafubaby in forum MediaReplies: 10Last Post: 5th Dec 2010, 18:05 -
Is using a Bluray drive better than a regular DVD drive?
By imfallen_angel in forum DVD RippingReplies: 14Last Post: 20th Mar 2010, 20:49 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 04:18 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 18:38 -
Lite-On drive LH-16W1P DVD-DL drive
By snafubaby in forum MediaReplies: 8Last Post: 28th Apr 2008, 15:00
