I have a small problem here....i want to completely install the software on my computer, except when it asks me to input a password, reenter password, then verify it, it wont accept the password installed, it always bounces back as if both were not matching or it was wrong.....besides the rest button on the router which obviously seems as if it doesnt want to work, can i get around this obvious problem!!!
Results 1 to 10 of 10
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
The reset button should set the l/p information back to default (as noted in the manual and setup sheets...NOT blank).
Google is your Friend -
and what is the default password again...admin right...yeah...THATS NOT WORKING EITHER!!!!!!!!
In the past I have typed admin for the userID not the password and been mystified by the fact it didn't work.
Any chance that you have done what I did? -
For initial login, leave the User field blank and type "admin" in the Password field.Originally Posted by SIRCOOKS
Will try....any other suggestions???????????
RTFM to verify the default login name and password, which I'm pretty sure is what Ollie stated, blank username and admin for the password. After the login there is a menu selection to change passwords.
First you must supply the currently valid login and password, this gives you access to make a new one. You are not running this software on the PC, you are using a program on the router itself. There is in fact little point to installing anything for the router on the PC itself. -
What if i cant remember the old password......then what????????
Hold down the reset button with a ball point pen for 20 seconds
That will reset the router back to factory defaults -
Page 50 of the manual.
If you don't have it, you can get it online: http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&ci...#versiondetailGoogle is your Friend
VPN and Static Routing with Linksys router
By CogoSWSDS in forum ComputerReplies: 0Last Post: 29th Aug 2009, 23:33 -
Filezilla FTP Client behind a Linksys N router - can't get it to work
By louv68 in forum ComputerReplies: 3Last Post: 3rd Mar 2009, 03:16 -
How Can I Set-Up the Linksys Wireless Router??
By Frank-0-Video in forum ComputerReplies: 9Last Post: 27th Feb 2009, 15:18 -
Can a router/wireless router shut down computer?
By tmh in forum ComputerReplies: 7Last Post: 29th Jan 2008, 12:34 -
Problwm with connecting to ftp using linksys router
By Wizard23 in forum ComputerReplies: 9Last Post: 3rd Nov 2007, 00:42
