hey guys,
a bit confused do all minidv's are the same in analog recording resolution?
i have a bullet cam of 420 tv lines resolution and i want to hook it up with mini dv and i want the best possible
resolution captures
and i have to choose with these two mini dv's:
1) sony dcr pc 55, 500 tv lines
2) canon zr 200, 520 lines
which one captures the best resolution? and why?
what if i use it in tv program? it doesnt matter?btw i use pal minidv
The lines of resolution has nothing to do with the number of horizontal lines that make up the image.
Crudely (and confusingly) it is more like the number of vertical lines that can be clearly distinguished before becoming a blurred, grey mess. Hence, it is how "sharp" the video is in the horizontal direction. -
Another way of saying it is 720x576 will be over sampling the analog input which doesn't add actual resolution to the picture but assures you are capturing what resolution is there. To max video quality (e.g. signal to noise ratio) one would low pass filter the analog input to just above the point where perceived "lines of resolution" drops. This would minimize capture of high frequency noise.
http://www.kiva.org/about -
i read some columns in a tech magazine about recording a tv program to mini dv and they mention that the recorded program is better than the original b/c mini dv's optimize color reproduction to make better-looking images., is that true?
Not that I've seen. DV camcorder analog pass through does some time base correction for VHS but the idea is to record color as it is presented.Originally Posted by nivek_nayrRecommends: Kiva.org - Loans that change lives.
Digital camcorders that have analog pass-thru & TBC
By djnice in forum Capturing and VCRReplies: 30Last Post: 19th Jul 2020, 04:57 -
Canon HV40 analog/digital pass through?
By stantheman1976 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 30th Jun 2011, 07:23 -
Analog to digital pass through with Sony Handycam DCR- HC65
By Gerald Sr. in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2008, 00:18 -
JVC Mini-DV deck for DV Pass-Thru for capturing Live TV?
By Deisel Weisel in forum Capturing and VCRReplies: 1Last Post: 10th Jan 2008, 11:02 -
What is the Best MiniDV Camcorder with analog/digital pass-through
By DigitalGuard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 20th Jun 2007, 15:18
