i have an avi file that when i play it, it has a green bar in the middle of the screen on my computer, but then i play it on a different computer the green bar is not there. how can i fix this?
probably the wrong video codec on your computer. Or yours is corrupted. Drop the file into GSPOT and see what exact kind of AVI it is, then get the correct codec and reinstall it.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
i tried but i don't think that the problem. beside when i loaded it nero vision and tried playing it i cant c the green bar. Any other suggestions?
That would show that the first program you used to play the file is using a corrupted or bad codec, and Nero is using a different one to play it. You might want to use Codec Sniper to find the bad codec.
I suspect the frame size is the problem. Some graphics cards have restrictions on the frame size for video overlay -- they must be a multiple of 4. Your video probably has a width or height that is a multiple of 2, not 4.
Open your video in two different players at the same time. If one is messed up and the other is OK this is the problem.
You can fix this by using a player that doesn't use video overlay, or reencoding the video with an acceptable frame size. -
wow thanks for that, it working now. i had the hight in the multiples of 4 but not my width.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
I want to demux an .mp4 file and convert to a microsoft dv .avi file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 13th Sep 2009, 22:42 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 22:22 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 12:39
