is there any tutorial that shows how to rip a dvd to a svcd with 2 audio traks???? if there is no such tutorial could someone tell me how please!!!!
The_Dogg
I assume you mean that you want to create a SVCD w/ 2 audio tracks (as most DVDs have more than 2 audio tracks). I don't know what programs/software you normally use so I'm going to assume TMPGenc et.al.
1) Rip DVD to HD
2) Use DVD2AVI to generate D2V file, and wav file for each track that you want (you'll have to extract each audio track seperately)
3) Use TMPGenc or tooLame to encode each wav -> MP2 (or MPA) file. I recommend using tooLame.
4) Use TMPGenc to encode D2V to M2V (ie. video only)
5) Run bbMPEG encode, and mux m2v (video) + audio1.mp2 + audio2.mp2 -> mpg
6) Burn as normal
To switch audio tracks on your hit the audio button on your remote. DVD2SVCD allows you to select multiple audio tracks.
Remember that the 2nd audio track is taking up bitrate too. Go to the 'Tools' section to the left, and run the vcdhelp.com bitrate calculator in advance mode and work out the bitrates you want. I would encode both audio tracks to 128.
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 13:24 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 12:16 -
need to substitute spanish audio track with english track
By rebeltaz in forum AudioReplies: 5Last Post: 26th Dec 2007, 19:12 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 08:25
