Have a 14.5gb HD show.It is in 100mb chunks.I also have them in a single .TS file.Neither will load in HDTV2DVD.The program just hangs and freezes.I ran it through Videoredo Plus "quick stream fix" and still no go.
I then made a sample 5mb of one of the 100mb chunks.That sample was able to load and I don't understand how since it came from a 100mb chunk that will not load in HDTV2DVD
I have other .TS files that load just fine.
Have any ideas?
Results 1 to 12 of 12
Yeah.Trying to figure out why it "somewhat" works.
I have a 9gb file that loads perfectly fine.I have even tried several of the 100mb chucks and they seem to load just fine but trying to add that file as a whole is just not happening.
Going to see what happens when I join half the files into approx. 7gb file and load it.
EDIT:
Cant load single 14.5gb file.HDTV2DVD hangs and get "Program Not Responding"
Run the file through VideoReDo "quick stream fix" and it fixes some things.
Cant load fixed file in HDTV2DVD.Program hangs and get "Program Not Responding"
I can load the individual 100mb chucks just fine.
Is 14.5gb too large?
EDIT #2
Here is the M2R log that perhaps cant help.
File Size Processed: 14.53 GB, Play Time: 01h:55m:43s
1920 x 1080, 29.97 fps, 17.40 Mbps (17.06 Mbps Average).
Average Video Quality: 69.50 KB/Frame, 0.27 Bits/Pixel.
AC3 Audio: 2/0 Channels (L, R), 48.0 kHz, 448 kbps.
Dialog Normalization: -31.0 dB
35 of 208097 video frames found with errors.
10 of 216984 audio frames found with errors.
348930 corrupted video bytes in file.
0.567233 seconds of video timestamp gaps.
0.576000 seconds of audio timestamp gaps. -
Is there no support for this being that it is free or something?
ffmpeg in H2D is an older version than in S2D. S2D is your best bet as I believe development has stopped on H2D.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
As Jikchung states no development on H2D has been done for ages and so it may struggle with some newer files. S2D has updated versions of ffmpeg so, in the main, that is why it loads your files more consistantly.
Drop me an email or PM about this and I will try to get it going for you.Originally Posted by jenevans33SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
CB, I believe you addressed jenevans33 issues here:
https://forum.videohelp.com/topic345829.html
Hopefully we'll get an update on whether that worked.Dwight
- Herm Albright
Good spot.
Yes, the registry edit did the trick for me. The program now starts correctly. Thanks all!
Jen
HDTV2DVD does not load up TS-file
By feilofix in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2008, 13:25 -
virtual dub wont load the full vob
By tvlreject in forum EditingReplies: 19Last Post: 28th Mar 2008, 20:13 -
How to load .ts file into HDTV2DVD?
By JR.S in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2007, 01:59 -
dvr-ms at 59.94fps wont load
By dalego in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 7th Oct 2007, 17:38 -
xvid wont load in program
By dvdhouse111 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 6th Jul 2007, 04:26
