Hi, is it possible to remove some of the New items fom the right click menu in vista ? Used to be really easy in Xp but Im a bit stumped with Vista.
In regedit, search for ShellNew. When you find an entry for one of the things you want to remove, delete the ShellNew key. Keep searching until you have completely searched HKEY_CLASSES_ROOT.
(The entries are by extension) -
Thanks for that , will try it later tonight.
Just had a quick try. Worked great. Dont you hate it when uninstall doesnt remove everything it should.
Thanks again.
Tip: How to add "detele" and "up" buttons in Vista/7
By roma_turok in forum ComputerReplies: 1Last Post: 3rd Jul 2010, 15:54 -
"shopping cart" for free items
By greymalkin in forum ComputerReplies: 1Last Post: 5th Apr 2010, 22:38 -
Windows Movie Maker (Vista) and "clips"
By freshone in forum Newbie / General discussionsReplies: 1Last Post: 31st Mar 2009, 17:26 -
Problem rebooting into Vista after "Safe Mode"
By RKelly in forum ComputerReplies: 1Last Post: 3rd Jan 2008, 23:31 -
SVCD2DVD "hangs" and then locks Vista
By tngin in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 25th Oct 2007, 15:31
