Hi There,
I have converted one of my .AVI file into .WMV format and tried playing it in PS3, but it says un-recognizable format.
(Note: I did set my PS3 options to play WMV (enabled) and is even upgraded with recent firmware)
But not sure why my WMV file couldn't play in PS3. I also tried to play one of my DIVX files, but the same message.
Am I doing any mistake here?
Is there any specific software, which can convert my AVI file into WMV format, which will play fine in PS3?
Also, is there any specific software to convert it into DIVX file and it can play in PS3?
I have lot's of MiniDV cassettes to be converted into either WMV or DIVX, so I can copy them into PS3 Hard Drive and play it when ever I want. (any suggestions on this please)
Please let me know your best suggestions.
Thank you all in advance.
Wow,
Thanks Baldrick,
That was a good and quick info. I will surely try this tonight.
Any more suggestions would be great.
Thank you all in advance. -
Hi Baldrick,
Yesterday night, I gave a try with Ripbot264, it really looks cool and easy to use.
But, the first time when I am trying to convert one of my AVI file to MP4, I selected an option to save the MP4 file into c:\ folder.
somehow, it did converted to MP4 file, but after it is converted, I couldn't find that file in C:\ folder. I did a search thru entire hard drive for .mp4 file, but I couldn't find it.
Later, I converted the same file and saved it onto my Desktop, and I am able to see the file on Desktop.
I am really not sure why this was happened.
I used this on Windows Vista machine, if that makes any difference.
Thank you for your input.
[HELP][ANIME] MKV (H.264 + AAC) to AVI (PS3 - Compatible) with soft-subs.
By mooshimuushi in forum Newbie / General discussionsReplies: 4Last Post: 21st Aug 2010, 01:42 -
MP4 with 2.0 audio: the only HD format compatible with BOTH ps3/xbox360?
By Randm in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2010, 13:09 -
Apple Quicktime HDV to AVI,or at least a windows compatible editing format
By SuperDre in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 2nd Mar 2009, 14:58 -
Free software that converts mpg2 or DVD to avi (divx) ???
By szalaikornel in forum Video ConversionReplies: 2Last Post: 13th Jan 2009, 02:52 -
Best simple software for HDTV camera footage to H264 PS3 format
By lneves in forum Video ConversionReplies: 34Last Post: 27th Jan 2008, 14:13
