When I burn a DVD that's made in Sony DVD Architect using the 16:9 mode it plays in 16:9 on my computer so I know it is burned properly. I go to place it in my Xbox360 and other DVD player it does no auto expand to fill my 16:9 TV. (it is squished in a 4:3 image) If I put in a commerical DVD such as a movie from Blockbuster/Netflicks both my XBOX360 and dvd player auto expand to fill the 16:9 video over the entire screen automatically.
So why does this happen with my home made DVD's that are set to 16:9 and play fine on my computer? I know my players are set up correctly because the commerical dvd's work properly.
The DVD displays properly if I go into the TV settings and place it in wide mode, but I don't want to do this b/c when I play a commerical dvd I then need to change it back.
So what's the key?
16:9 is set at two points in DVD authoring. The first is when you encode the video. The video must be encoded as 16:9 so that the appropriate headers are set in the stream. When the disc is authored it must be authored as 16:9 to ensure the IFO files correctly reflect the aspect ratio for playback.
Software players may check either of these points, hence some play it back correctly. However I suspect one of them is not right, or everything would play it back correctly.Read my blog here.
I was able to check the IFO file and below is what I got. Everything looks fine to me both 16:9. The menu is just an image from Sony DVD Architect and my video file is 1280 x 720 straight from my camera. But still no luck. Is there a way to double check the encoding of the video?
if you double click on the vts_1 video attributes does is have automatic letterbox or letterbox(top and bottom cropped) checked?
automatic letterbox I checked when i open the vts_1Originally Posted by aedipuss
Expanding the whole subtitle
By Night 89 in forum SubtitleReplies: 3Last Post: 2nd Jan 2012, 20:13 -
expanding menus
By dread in forum Authoring (DVD)Replies: 1Last Post: 31st Aug 2008, 05:16 -
Commerical DVD v/s DV->DVD quality difference ?
By Movie-Maker in forum Newbie / General discussionsReplies: 6Last Post: 16th Aug 2008, 15:21 -
Expanding AVI to eliminate line flicker
By yukon33 in forum EditingReplies: 1Last Post: 18th Feb 2008, 10:28 -
ColorSpace for commerical DVD's
By mlong30 in forum EditingReplies: 6Last Post: 29th May 2007, 21:16
