hi, i'm Kevin and i'm from Brasil...
my 1st post is already a question but it's been around 6 months that i'm lookin for a solution for this problem
i have lots of TV Shows episodes and since my dvd font SUCKS! (and cannot be edited), i like to burn-in the subtitles into the main file but the thing is:
i don't want it to get bigger or smaller. i'd like to get the output (subtitled) files with the same 350 MB.
i use WinAVI cos it recognizes the subs and i can edit the way it'll be showed the way i like (Tahoma, yellow, 24) but even tryin MANY (around a hundred times) lots of XviD configs using tutorials i found online, none of them worked yet
pls, any help is MUCH appreciated
Try instead AutoGK and use ssa subtitles where you can specify font, colors, etx, see https://forum.videohelp.com/topic316471.html
And moving you to our subtitle forum. -
thanks a fuckin lot!!!! man, it really worked...
and so sry postin in wrong place -
i tried with a band's video clip and it did worked wonderfully... but today with a tv show episode:
Code:[14/2/2008 11:41:16] AutoGK 2.45 [14/2/2008 11:41:16] OS: WinXP (5.1.2600).2 [14/2/2008 11:41:16] Job started. [14/2/2008 11:41:16] Input file: C:\...\Vids\Show\TV_Show-s01e01.avi [14/2/2008 11:41:16] Input codec: XviD [14/2/2008 11:41:16] Source duration: 42mn 15s 783ms [14/2/2008 11:41:16] Output file: C:\...\Vids\TV_Show-s01e01.avi [14/2/2008 11:41:16] Output codec: XviD [14/2/2008 11:41:16] Audio 1: 132 Kbps VBR MP3 2ch [14/2/2008 11:41:16] Subtitles: from external file: C:\...\Vids\Show\TV_Show-s01e01.ssa [14/2/2008 11:41:16] Format: AVI [14/2/2008 11:41:16] Target size: 349Mb [14/2/2008 11:41:16] Audio 1 settings: Auto [14/2/2008 11:41:16] Started encoding. [14/2/2008 11:41:16] Source resolution: 624x352 [14/2/2008 11:41:16] Source fps: 23,976 [14/2/2008 11:41:16] Output will contain 60798 frames [14/2/2008 11:41:16] Demuxing audio. [14/2/2008 11:41:25] Preparing subtitles. [14/2/2008 11:41:25] Audio1 size: 41,847,696 bytes (39.91 Mb) [14/2/2008 11:41:25] Overhead: 2,431,872 bytes (2.32 Mb) [14/2/2008 11:41:25] Video size: 321,673,456 bytes (306.77 Mb) [14/2/2008 11:41:25] Running compressibility test. [14/2/2008 11:41:25] Writing the following script to C:\...\Vids\agk_tmp\TV_Show-s01e01_comptest.avs =========================================================== LoadPlugin("C:\ARQUIV~1\AutoGK\DGMPGDec\DGDecode.dll") LoadPlugin("C:\ARQUIV~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\ARQUIV~1\AutoGK\filters\vsfilter.dll") LoadPlugin("C:\ARQUIV~1\AutoGK\filters\RemoveGrainSSE3.dll") movie = DirectShowSource("C:\...\Vids\Show\TV_Show-s01e01.avi",23.976).KillAudio() movie = isRGB(movie) ? ConvertToYV12(movie) : movie movie = isYUY2(movie) ? ConvertToYV12(movie) : movie cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=0,samplestartframe=0,leftadd=0, rightadd=0,topadd=0,bottomadd=0) fixed_aspect = 1 c_width = width(cropclip) c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) input_par = (input_par > 1.4) || (input_par < 1.25) ? input_par : (4.0/3.0) out_width = 624 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=0,samplestartframe=0, leftadd=0,rightadd=0,topadd=0,bottomadd=0) LanczosResize(out_width,out_height) TextSub("C:\...\Vids\Show\TV_Show-s01e01.ssa") SelectRangeEvery(300,15) =========================================================== [14/2/2008 11:42:32] Duration was: 1 minute, 6 seconds [14/2/2008 11:42:32] Speed was: 45,64 fps. [14/2/2008 11:42:32] Compressibility percentage is: 60,47 [14/2/2008 11:42:32] Chosen resolution is: 608x352 ( AR: 1,73 ) [14/2/2008 11:42:32] Predicted comptest value is: 62,06% [14/2/2008 11:42:32] Running first pass. [14/2/2008 11:42:32] Writing the following script to C:\...\Vids\agk_tmp\TV_Show-s01e01_movie.avs =========================================================== LoadPlugin("C:\ARQUIV~1\AutoGK\DGMPGDec\DGDecode.dll") LoadPlugin("C:\ARQUIV~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\ARQUIV~1\AutoGK\filters\vsfilter.dll") LoadPlugin("C:\ARQUIV~1\AutoGK\filters\RemoveGrainSSE3.dll") movie = DirectShowSource("C:\...\Vids\Show\TV_Show-s01e01.avi",23.976).KillAudio() movie = isRGB(movie) ? ConvertToYV12(movie) : movie movie = isYUY2(movie) ? ConvertToYV12(movie) : movie cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=0,samplestartframe=0,leftadd=0, rightadd=0,topadd=0,bottomadd=0) fixed_aspect = 1 c_width = width(cropclip) c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) input_par = (input_par > 1.4) || (input_par < 1.25) ? input_par : (4.0/3.0) out_width = 608 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=0,samplestartframe=0, leftadd=0,rightadd=0,topadd=0,bottomadd=0) LanczosResize(out_width,out_height) TextSub("C:\...\Vids\Show\TV_Show-s01e01.ssa") =========================================================== [14/2/2008 11:51:18] Duration was: 8 minutes 46 seconds [14/2/2008 11:51:18] Speed was: 115,54 fps. [14/2/2008 11:51:18] Expected quality of first pass size: 60,71% [14/2/2008 11:51:18] Running second pass. [14/2/2008 12:10:25] Duration was: 19 minutes 7 seconds [14/2/2008 12:10:25] Speed was: 53,01 fps. [14/2/2008 12:10:25] Job finished. Total time: 29 minutes 8 seconds
then i tried to change Audio 1 settings: Auto for Audio 1 settings: VBR MP3 with average bitrate: 128Kbps, then look what it gave me:
Code:[14/2/2008 16:45:16] AutoGK 2.45 [14/2/2008 16:45:16] OS: WinXP (5.1.2600).2 [14/2/2008 16:45:16] Job started. [14/2/2008 16:45:16] Input file: C:\...\Vids\Show\TV_Show-s01e01.avi [14/2/2008 16:45:16] Input codec: XviD [14/2/2008 16:45:16] Source duration: 42mn 15s 783ms [14/2/2008 16:45:16] Output file: C:\...\Vids\TV_Show-s01e01.avi [14/2/2008 16:45:16] Output codec: XviD [14/2/2008 16:45:16] Audio 1: 132 Kbps VBR MP3 2ch [14/2/2008 16:45:16] Subtitles: from external file: C:\...\Vids\Show\TV_Show-s01e01.ssa [14/2/2008 16:45:16] Format: AVI [14/2/2008 16:45:16] Target size: 349Mb [14/2/2008 16:45:16] Audio 1 settings: VBR MP3 with average bitrate: 128Kbps [14/2/2008 16:45:16] Started encoding. [14/2/2008 16:45:16] Source resolution: 624x352 [14/2/2008 16:45:16] Source fps: 23,976 [14/2/2008 16:45:16] Output will contain 60798 frames [14/2/2008 16:45:16] Demuxing audio. [14/2/2008 16:45:24] Preparing subtitles. [14/2/2008 16:45:24] Audio1 size: 41,847,696 bytes (39.91 Mb) [14/2/2008 16:45:24] Overhead: 2,431,872 bytes (2.32 Mb) [14/2/2008 16:45:24] Video size: 321,673,456 bytes (306.77 Mb) [14/2/2008 16:45:24] Running compressibility test. [14/2/2008 16:45:24] Writing the following script to C:\...\Vids\agk_tmp\TV_Show-s01e01_comptest.avs =========================================================== LoadPlugin("C:\ARQUIV~1\AutoGK\DGMPGDec\DGDecode.dll") LoadPlugin("C:\ARQUIV~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\ARQUIV~1\AutoGK\filters\vsfilter.dll") LoadPlugin("C:\ARQUIV~1\AutoGK\filters\RemoveGrainSSE3.dll") movie = DirectShowSource("C:\...\Vids\TV_Show\TV_Show-s01e01.avi",23.976).KillAudio() movie = isRGB(movie) ? ConvertToYV12(movie) : movie movie = isYUY2(movie) ? ConvertToYV12(movie) : movie cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=0,samplestartframe=0,leftadd=0, rightadd=0,topadd=0,bottomadd=0) fixed_aspect = 1 c_width = width(cropclip) c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) input_par = (input_par > 1.4) || (input_par < 1.25) ? input_par : (4.0/3.0) out_width = 624 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=0,samplestartframe=0, leftadd=0,rightadd=0,topadd=0,bottomadd=0) LanczosResize(out_width,out_height) TextSub("C:\...\Vids\TV_Show-s01e01.ssa") SelectRangeEvery(300,15) =========================================================== [14/2/2008 16:46:31] Duration was: 1 minute, 6 seconds [14/2/2008 16:46:31] Speed was: 45,55 fps. [14/2/2008 16:46:31] Compressibility percentage is: 60,47 [14/2/2008 16:46:31] Chosen resolution is: 608x352 ( AR: 1,73 ) [14/2/2008 16:46:31] Predicted comptest value is: 62,06% [14/2/2008 16:46:31] Running first pass. [14/2/2008 16:46:31] Writing the following script to C:\...\Vids\agk_tmp\TV_Show-s01e01_movie.avs =========================================================== LoadPlugin("C:\ARQUIV~1\AutoGK\DGMPGDec\DGDecode.dll") LoadPlugin("C:\ARQUIV~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\ARQUIV~1\AutoGK\filters\vsfilter.dll") LoadPlugin("C:\ARQUIV~1\AutoGK\filters\RemoveGrainSSE3.dll") movie = DirectShowSource("C:\...\Vids\Show\TV_Show-s01e01.avi",23.976).KillAudio() movie = isRGB(movie) ? ConvertToYV12(movie) : movie movie = isYUY2(movie) ? ConvertToYV12(movie) : movie cropclip = utocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=0,samplestartframe=0,leftadd=0, rightadd=0,topadd=0,bottomadd=0) fixed_aspect = 1 c_width = width(cropclip) c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) input_par = (input_par > 1.4) || (input_par < 1.25) ? input_par : (4.0/3.0) out_width = 608 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=0,samplestartframe=0, leftadd=0,rightadd=0,topadd=0,bottomadd=0) LanczosResize(out_width,out_height) TextSub("C:\...\Vids\Show\TV_Show-s01e01.ssa") =========================================================== [14/2/2008 16:52:34] Duration was: 6 minutes 2 seconds [14/2/2008 16:52:34] Speed was: 167,80 fps. ************************************* EXCEPTION: Number of frames is very different from expected. Found 3045 frames. ************************************* [14/2/2008 16:52:34] Job finished. Total time: 7 minutes 17 seconds
Code:Avisynth open failure: Evaluate: System exception - Access Violation (C:\...\TV_Show-s01e01_movie.avs, line 9)
DV-AVI / Format size
By willmington in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2011, 10:49 -
Encoding AVI's by Size
By OrchestraAndChoir in forum Video ConversionReplies: 6Last Post: 15th Sep 2009, 15:40 -
Trying to shrink avi size, and more!
By janlafata in forum Video ConversionReplies: 8Last Post: 21st Dec 2008, 13:12 -
Subtitled AVI Movie File - Can't Convert To DVD Format Without Glitches
By TheGimp in forum ffmpegX general discussionReplies: 13Last Post: 19th May 2008, 00:48 -
Avi -> Smaller size
By gamerinha in forum Newbie / General discussionsReplies: 6Last Post: 27th Jun 2007, 11:29
