I wonder whats behind the issue when Windows Explorer allways and directley crash as soon as you physical touch a certain video file with the mouse, its allways only 1 file at time thats being affected, and there should be some month between them
I have tested to kill "K-lite Codec pack", this far i have atleast concluded thath in my case this codec pack is the trigger of the crashes, but i dont know wich codec i shall unmark when i install it from the start, cause this must be a codec conflict right, so what i can ask you i guess is wich codecs is known to not co-operate in codec packs generally? and have you experienced this yourself?
As much as I want to blame the codec pack, it's probably the old issue with Explorer generating thumbnails for each video file when you select them in Explorer.
Try this:
Start > Run > enter "regsvr32 /u shmedia.dll" (without the quotes). See if that helps.
To reverse that, use "regsvr32 shmedia.dll" instead of the above command.If cameras add ten pounds, why would people want to eat them? -
I have performed it now, its hard to judge if it helped, cause i have concluded thath the file is screwed up totally, seens it doesnt even play in VLC player with any single codec combinations, after uninstalling K-lite-codec pack the crashes atleast stopped (could allso bet he registry fix)Originally Posted by Ai Haibara
anyway im sure your registry fix will help in various future areas, thanks
Touch screen monitors or all in one touch screen pc?
By Rudyard in forum ComputerReplies: 4Last Post: 1st Dec 2010, 09:02 -
One Touch Grabber Problem
By elwood55 in forum Capturing and VCRReplies: 0Last Post: 4th Sep 2010, 17:26 -
Touch Screen Monitor.
By slimmx in forum ComputerReplies: 1Last Post: 25th May 2008, 08:50 -
ipod touch
By warwickk in forum Newbie / General discussionsReplies: 1Last Post: 31st Dec 2007, 12:13 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38
