Hello im quite good at scanning the face of a dvd and then taking the image to my R200 and making a very good backup!
My question is when i have a dvd that has the mirror finish on it how can i do those? They dont scan worth a crap.
Is there a way to lift the text off?
I see you can buy mirror print to hub dvds now?
Has anyone done this?
Please help
Kentucky
Results 1 to 11 of 11
The DVD blanks you are talking about (mirror print to hub) are just for text and nothing else. They are called "thermal printable". You can't print graphics to mirror finishes.
I'm sorry, but I don't know the answer to your question about scanning. Good question though. -
Just a thought, but what about taking a photo of the disk with a digital camera?
Use the dvd cover art. To make it look anything but crappy: You'll have to have some photo editing ability. If you resort to lightscribe: scan the original in black & white and clean it up.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Try looking here for cover art: http://www.cdcovers.cc/covers
Lots of discs have shiny surfaces or just bland, blah text and for those discs there are usually "custom" versions in the list. -
Yes. http://www.rima.com sells them, as do other stores.Originally Posted by kentucky
You do understand that you CANNOT print graphics to these discs, right? -
I'm being very generous in giving you some serious benefit of the doubt here because you are new, but you don't seem to really be paying attention to the posts here. I'm starting to lose interest in continually responding.Originally Posted by kentucky
You can print to the mirror finish disks with a THERMAL PRINTER ONLY. You can ONLY print text. No graphics. Scans of DVD labels are graphics.
I am working from memory here, but I seem to recall that the r200 is some kind of ink jet or something similar. That will NOT work on these discs! If I am wrong and the r200 is a thermal printer, then yes, it will work. It's your printer, so you can figure out whether it will work or not. -
If you need to print on a silver color DVD-R check to following link
http://www.rima.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=R&Product_Code=1739-1...tegory_Code=DM
this disk will work with your R-200 printer. You can print inages and/or text.
Epson R200, new cheaper disk printer?
By The village idiot in forum MediaReplies: 309Last Post: 26th Mar 2012, 09:56 -
Win7 drivers for the Epson R200?
By MrSpeed in forum MediaReplies: 0Last Post: 27th Apr 2010, 04:50 -
Mirror copy of Pinnacle DVD
By Straightlegger in forum Authoring (DVD)Replies: 2Last Post: 1st Feb 2010, 11:40 -
Epson R200 printer and DVD art
By dymx in forum ComputerReplies: 4Last Post: 8th Jul 2008, 11:57 -
Growing very tired of Epson's R200 - R220
By stiltman in forum MediaReplies: 25Last Post: 25th Jun 2008, 23:58
