I'm trying to add subtitles to a divx file with TMPGEncDVD Author 3. I add the subs in .srt format and when I run "Simulation" the subtitles work but when I "Start" the conversion process the subs don't show up on the "preview" screen. I even let the whole conversion process run (about 1 hour and 45 minutes) to see if they'd show up on the file when the conversion was finished but they didn't. I'm new at this, can anyone give a brother some advice? Thanks in advance.
How are you playing the converted dvd? You need a software dvd player and open the video_ts folder and then probably also enable the subtitles because they are switchable.
I appreciate your reply. I haven't even tried to burn the file because (as I said previously) it didn't appear the subtitles were added even after the full conversion (despite the fact that if I look at "simulation" prior to conversion the subtitles work. I burn divx files all the time with Nero by putting them on a dvd disc and burning them as data files. They all work perfectly when I play them on my dvd/divx player connected to my tv. Many thanks again for any help/advice.
Creating my own subtitles and adding them to an AVI (divx) file? Best way?
By Chrushev in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 05:12 -
adding subtitles to AVI (xvid or divx) WITHOUT re-compressing
By truthlesshero in forum SubtitleReplies: 2Last Post: 22nd Dec 2009, 11:43 -
Adding Subtitles to divx w/ a .sub file
By sean2a in forum SubtitleReplies: 5Last Post: 28th Sep 2008, 17:23 -
Adding graphic subtitles to Divx with correct sizes/positions?
By picrade in forum SubtitleReplies: 1Last Post: 1st Apr 2008, 04:13 -
Adding chapters in TMPGEnc DVD Author 3 with DivX Authoring?
By T_virus in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2007, 20:53
