Results 1 to 9 of 9
  1. Member spiritgumm's Avatar
    Jan 2004
    I use TDA 1.6 which allows you to substitute an image for a button, but the imported image is always in a squarish frame. That is, if you want the button to be a cartoon dog instead of the template word "Play", the dvd player will highlight the dog and background around it. I've gotten dvds where only the image is highlighted - like there's a mask outline around just the desired image. What programs offer this? Can I tweak my TDA ware to do this?
    Oct 2006
    Canada
    I am not sure about TDA, but DVD Lab will let you do that.
  3. Member spiritgumm's Avatar
    Jan 2004
    thanks!
    Sep 2007
    Save the desired image in a format that supports transparency, such as .PNG or the native Photoshop format, .PSD
    Oct 2006
    Canada
    It is not just a matter of transparency. I do not think template based software can work with layers on custom made picture.
    Sep 2007
    Works fine for me, in TDA 2 and 3.
  7. Member spiritgumm's Avatar
    Jan 2004
    I'll give the psd file a shot. I might need some advice if it doesn't work immediately.
    Sep 2007
    Here's a guide for doing this.
  9. Member spiritgumm's Avatar
    Jan 2004
    Cool. I hope it works with TDA 1.6
    LATER: Yes, just using a psd image with transparent background works in TDA 1.6. The menu button highlighting only effects the image, too.
