    Feb 2008
    When copying the second side of a two-sided disc that I own, there are two episodes on the flip side, but it is only recognizes one of the episodes. There are two epidsodes. I have 3 discs of the same show that does this. How do I get it to recognize the second episode?
    Michelle
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Depnds on exactly what you are doing and which tools you are using. It sounds like you have a scratched/damaged disc that the software can't read.
    Google is your Friend
