Having downloaded a few .avi video files, after encoding is complete on viewing I find that they all suffer from a slight fault in the graphics motion. Every second or so there is a slight jump or hiccup, not major but still discernible. Can I improve this or is it more to do with the original bitrate or compression preferences that the author has placed on it.![]()
1/ Converting your AVI files to what format?
2/ What is the original and target framerate?
3/ What conversion tool(s) did you use? -
Sounds like you converted 23.976 fps NTSC film to 25 FSP PAL by duplicating one frame out of every 24. A better approach (used by commercial DVD) is to speed up the frame rate. Of course, the audio has to be sped up too.
Sound hiccups in DVD-lab slide show
By seajeep in forum Authoring (DVD)Replies: 0Last Post: 13th Oct 2011, 11:04 -
AVCHD thru Premiere CS4 encodes hiccups in audio
By ddane in forum Video ConversionReplies: 5Last Post: 11th Dec 2009, 17:21 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 21:11 -
Video Music Clips with Hiccups
By zenzen1 in forum Software PlayingReplies: 4Last Post: 23rd Aug 2008, 23:09 -
Audio gaps/glitches/hiccups when importing long play DV footage
By teraldlarwood in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 12th Apr 2008, 08:34
