Im using DVD Decrypter to rip my DVD to my HD. What im doing is selecting the VOBs that matter (the ones with the actual video content on them) and the audio is off. This doesnt happen often, but its been happening more and more with certain DVDs. I analyzed the vob file on the DVD and its NTSC, so it isn't a pal \ ntsc problem. Any suggestions?
Sorry, Im a beginner.
DVD DECRYPTER is no longer updated. Use DVDFAB HD DECRYPTER to rip to your hard drive.
If using DVD Decrypter with an older movie to make an AVI or something, then use DVD Decrypter in IFO Mode (up at the top, Mode->IFO). File Mode is the default.
And if you're trying to decrypt a newish movie that might have one of the newer copy protections, then take budz' advice and use DVDFab HD Decrypter. One of the things the new copy protections do is mess up the audio synch unless they're decrypted properly. Yes, it works with regular DVDs. -
Thats pretty awesome.. I didnt know that! Ty much kind sirs
how to change the Menu without messing up the whole DVD structure?
By yozloy in forum Authoring (DVD)Replies: 1Last Post: 22nd Dec 2010, 11:12 -
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Ripped with DVD Decrypter - No Audio
By ezen in forum DVD RippingReplies: 7Last Post: 22nd Oct 2008, 01:05 -
Audio going too fast for FLV, really messing me up :(
By sigpikul in forum ffmpegX general discussionReplies: 3Last Post: 28th Feb 2008, 14:14 -
Burn audio CD with ImgBurn and DVD Decrypter - not enough space
By theWallflower in forum AudioReplies: 11Last Post: 7th Aug 2007, 16:21
