    May 2007
    What tool can I use to give part of an AVI clip a slow-motion effect?
  2. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    I found a few ways to do it a couple of weeks ago by using the Advanced search function at the top of almost every page 8)
    https://forum.videohelp.com/search.php?sid=2720a04e022c81c9bcfa7d83d1d9329e#search
    USA
    One method: https://forum.videohelp.com/topic344986.html
    And this isn't DVD Authoring. Moving you to the Newbie Conversion Forum.
  4. Member Nitemare's Avatar
    Jan 2003
    Knowing what software you plan to use would be helpful. The Above post is for VirtualDub, an excellent piece of freeware, and will work okay. If you already have video editing software, tell us what you're using and you'll get a better answer.
    Even a broken clock is right twice a day.
  5. Banned
    Jun 2004
    8)
  6. Member Nitemare's Avatar
    Jan 2003
    sorry 'bout that... I was having a blonde moment I suppose. Just about ANY video editor will let you do this... VirtualDub is as good (and sometimes better) than anything out there.
