hello guys ...
I've been tired of this problem i got everytime i update megui
if i didnt use it for some time .. when i come to use it again i got error because i have to update megui
so when i update it and try the same way i used to encode .. it takes almost 3 hours processing without reaching even 30% .. then the computer (Laptop) shutdown suddenly !
considering that encoding one 24min episode was taking in this same computer almost 80min to complete .
and i did use megui many times before successfully..
but now its 3 hours and never complete !!
what do i have to do now ?
what might be the problem is ?
is there any particular files should i have to add or install or update or put it in megui folder .. etc ?
please help !
no matter what i tryed this time it never worked correctly !
it seems that the problem happen in job3 of the process
job1 and job2 completed successfully
but job3 its been now an hour and still 10% in process !!
at this rate i know it wont be completed even after another 1 or 2 hours !
as in this picture
http://xs224.xs.to/xs224/08073/megui721.jpg
anyone knows what to do ? please ! -
Insecticide.
u have bugs. serious bugs. viruses. spyware. Re-format hdd and start again. -
While there is a possibility of a virus I wouldn't go through the drastic measure of re-formating your hard drive until you rule out other problems. Since your first two files finished fine then more than likely there is an error in the 3rd source file that's causing megui to go bonkers. Although it couldn't hurt to scan your hard drive with your antivirus software.
Donadagohvi (Cherokee for "Until we meet again") -
i dont think its bug or virus becase i tried same thing on another computer with even a better RAM ( 512MB) after it had been formatted ..
and the same problem occured !!
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 16:57 -
Computer keeps shutting off
By black cloud in forum ComputerReplies: 18Last Post: 2nd Aug 2011, 21:54 -
Computer keeps shutting down
By mac71671 in forum ComputerReplies: 8Last Post: 29th Jan 2010, 09:45 -
By didikai in forum Newbie / General discussionsReplies: 22Last Post: 31st Aug 2008, 08:24 -
Computer keeps shutting down, won't stay on.
By Super Warrior in forum ComputerReplies: 6Last Post: 9th Aug 2007, 15:34
