Looking to make a music CD w/ multiple formats producing the broadest compatibility. (I've only ever listened to my music files on my PC, so believe it or not, I have not tackled this.) Recommendations? Thank you!
Results 1 to 12 of 12
Just make a simple audio CD. Every burning software supports this. There is nothing more compatible. Plays in car CD players, walkmans, DVD players, boom boxes, computers, and on and on.
Formats would make it not compatible.
Is this a serious question?Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
I'm serious. I burned an mp3 to a CDR with Windows and it wouldn't play in my CD player. What do you use? Thanks!
AUDIO CD
Not mp3/wmv/wav or anything else. Audio CD.
Nero, RecordNow, Burnnn!, and every other burning software has the option to create an AUDIO CD not MP3 cd, not data cd.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
IMGBurn isn't really recording software, but an IMG burner. Though Lightning UK is adding other functions all the time.Originally Posted by kippard
For other freeware/opensource that can do this, check out InfraRecorder http://infrarecorder.sourceforge.net/ or Burrrn http://www.burrrn.net/?page_id=4Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
You need an application that fully supports the Redbook Audio CD specification, and to use good quality, high reflectivity blanks. If you have a low budget, consider Prassi ONES. If you have a decent budget, look at CD Architect from Sony (written in the Sonic Foundry days)
Read my blog here.
That's only from a CUE file,I honestly don't know why Lightning UK would muck up a great program by adding that feature.Originally Posted by kippard
Back on topic:Use CDBurnerXP -
You can load wav files (ect) into it, then it makes a cue sheet and burns, you do not have to have a pre-existing cue sheet.Originally Posted by MOVIEGEEK
Best video format for long term compatibility?
By mart0224 in forum Video ConversionReplies: 11Last Post: 20th Sep 2008, 23:39 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 17:29 -
multiple images imbedded in a music file
By Aaron1978 in forum AudioReplies: 3Last Post: 20th Apr 2008, 12:18 -
DVD Slideshow w/ Multiple Background Music
By carbfrze in forum Authoring (DVD)Replies: 7Last Post: 28th Oct 2007, 23:04
