    Feb 2008
    Netherlands
    Is the Logitech 525 remote capable of doing this (for the Sony RDR-HX750):
    https://www.videohelp.com/dvdhacks/sony-rdr-hx750/8266
    I'd like to know, so I can borrow the remote to perform the hack.
    Thank you!
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    While the Harmony remotes are programmable, they are only programmable using the supoprted device list within the Logitech software which pulls the hardware/remote information from a database provided by Logitech. I don't believe they can be programmed without using the Logitech software (though I haven't tried). And I don't believe Logitech has the service remote codes available.
    If you are only borrowing the remote, then it doesn't seem like much hassle to try it and see what happens.
    Google is your Friend
