I have 2 p.c.'s and i set of 5.1 speakers, is there a waya i can have the 2 pc's share the one set of speakers?????
Results 1 to 16 of 16
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
Radio Shack or an electronics supply store should be able to set you up with a manual A/B switch to handle the task.
Can you give me a pic or a url so i can know better what to look for.
If you Google "google" you can find these yourself:
http://www.cablestogo.com/product.asp?cat%5fid=3111&sku=52065 -
Pay attention to the connector types and numbers. The switch that Video Head pointed out only does stereo via mini pin-plugs.
Yup. That's what most sound cards in PC's and amplified computer speakers have. You can also get A/B switches for unbalanced 3 pin XLR if that is your requirement.Originally Posted by jagabo
Thanks man...
Yes, but a 5.1 system may be using SPDIF, optical, or multiple sets of pin plugs.Originally Posted by Video Head
I can always get the adapter for these plugs right???????????????
For pin plug to RCA connectors yes. My 4.1 speaker system connects to the computer with a pair of stereo pin plug cables. You would need two of those switch boxes to handle that.Originally Posted by SIRCOOKS
My KVM has audio. I use one set of speakers, one monitor, one mouse, one keyboard -- 3 separate computers.
There are multitudes of switchers and switchboxes being built. They can handle just about any input and output. Some can convert unbalanced to balanced, some are fully automatic, some manual and some use remote controls and triggers. Some go into wallplates to control A/V throughout an entire multiroom installation. Some cost $10, some cost $1,000's...
The OP's question was can this be done...the short answer is yes, an A/B switch will accomplish this.
They were then pointed in the direction of an example. Without knowing what exact connectors they have or will have or might buy in the future it is impossible to say exactly which one. Googling on their own might help to find the exact one they need. The OP is going to have to put in at least a minimal amount of effort. I suggest going to an electronics supply store and explain to the man that you "need an A/B audio switch to accomplish (insert specific needs here)". -
Just to toss another option into the confusion, this $39.99 mixer allows you to use normal analog pots to mix and eq the sound from your computers, TV, DVD player, CD player etc. to one amp.
Best to learn how to solder so you can avoid paying $$ for all the cables.
http://www.musiciansfriend.com/product/Behringer-Eurorack-UB802-Mixer?sku=631238
Manual http://img3.musiciansfriend.com/dbase/pdf/man/m_631238.pdfRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Haha!Originally Posted by edDV
My old anolog mainboard is now relegated to being a switcher and EQ...
And this Mackie rip off is only $39.99.
PC Speakers, which ones?
By SE14man in forum Newbie / General discussionsReplies: 8Last Post: 28th Sep 2011, 15:41 -
How to run 2 computers off of one set of computer speakers?
By Denvers Dawgs in forum ComputerReplies: 14Last Post: 7th Feb 2010, 10:54 -
Does 7.1 audio limit the rear speakers and divert to the side speakers?
By yoda313 in forum AudioReplies: 0Last Post: 4th Oct 2009, 10:55 -
Need to Remove Logo for a set time at a set place.
By Ensign in forum EditingReplies: 3Last Post: 11th Sep 2009, 16:39 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 16:59
