Results 1 to 12 of 12
    Feb 2008
    hongkong
    hey guys, any one who knows how to calculate the video bitrate of a video?
    and what bitrate of a video taken from a digicam? like sony dsc's the vids look clear,and vivid images,
  2. Assuming the videos are files somewhere:
    bitrate (Mbps) = 8 x file size (in MB) / duration (in seconds)
    Feb 2008
    hongkong
    why 8 is given?
    example 55.5 mb file size, duration is 39 sec
    so what actually the bitrate?
    Because 1 byte = 8 bits.
    8 x 55.5MB / 39 secs = 11.38Mbps total bitrate (video and audio)
    Feb 2008
    hongkong
    tnx for quick reply
    more power to this forum..
  6. DV from a digicam will always be 25 Mb/s
    Feb 2008
    hongkong
    so thats why digicam vids eats a lot of memory?
  8. Yup, 1 hour = 13GB! And it's why DV is such high quality.
    HDV cams use exactly the same bitrate but use a much more aggressive compression scheme (MPEG2).
    Feb 2008
    hongkong
    how about the video bitrate of sony digital cameras like sony t9,t10,t100
    these camera produce sharper and clorful videos,near dvd quality.
  10. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    From: http://www.imaging-resource.com/PRODS/T7/T7A.HTM
    "In Movie exposure mode, the camera captures either 640 x 480-, or 160 x 112-pixel resolution moving images with sound for as long as the memory card has available storage space. At the 640 x 480 setting, you can choose between Standard and Fine quality options. Standard records at 16 frames per second, while Fine records at 30 frames per second and requires Memory Stick PRO Duo media to support the necessary data rates."
    Record a minute of video at 30fps and use the formula above to calculate bit rate from the file size recorded.
    http://www.kiva.org/about
    Feb 2008
    hongkong
    tnx a lot
  12. Bitrates of different codecs don't compare directly though.
