I have recorded Discovery Atlas HD through DVBViewer in TS format, and would like to be able to view it in Zoomplayer. My problem is that when I open the file, I get picture, but no sound OR subtible. Funny thing is, when I play it in VLC I can hear the sound and also select the DVB subtitle. In PowerDVD I can hear the sound, but not possible to select DVBsubtitle
Is it possible to get the two things to work in Zoomplayer?
Have you tried install the haali media splitter and configure so it's used in zoom player.
Not only does it need to be installed, but you media player has to configured to use it as the decoder/codec.
Google is your Friend
MPEG TS recorded from DVB: impossible to extract subs good enough for OCR
By edea in forum SubtitleReplies: 25Last Post: 25th Oct 2011, 13:07 -
DVB-S/DVB-S2 Satellite Receiver with direct HD,SD/SDI output not HDMI
By rahemeen in forum DVB / IPTVReplies: 1Last Post: 19th May 2011, 06:38 -
Does Zoomplayer has it's own subtitle renderer like MPC?
By natsume shin in forum SubtitleReplies: 5Last Post: 29th Oct 2008, 11:37 -
Playing HD DVD And Blu-Ray in Zoomplayer
By bjur in forum Software PlayingReplies: 3Last Post: 13th Feb 2008, 11:07 -
Captured dvb-s dvb-t mpeg video to DVD
By tonut in forum Authoring (DVD)Replies: 6Last Post: 7th Sep 2007, 08:02
