Hi,
I want to recode some mp3 at a lower kbps. It looks as if ffmpeg can do that (you can select your kbps) but the resulting files are 0k (empty). Can anyone help?
I am on MAC. I tried compressor but it doesn't ave an mp3 output.
Thank you!
If you rebel, be efficient.
First, MP3 is an audio format. Are you sure that VIDEOhelp.com
is the right place to be?
But I digress.
Get a copy of Amadeus (free to try). Read in the MP3, do a
save-as, select MP3, and set the desired bitrate via the
options button.Al Bloom -
For audio-only files, you have to check the "invert mapping" box under the Audio tab in ffmpegX.
Jean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés -
Here is a solution I have offered for people who want just the audio track from a video, but it would work in your instance as well. Try this:
http://geek.thinkunique.org/2007/09/04/make-an-mp3-out-of-your-video/
It is a droplet onto which you drop your decrypted vob or mpeg or avi, and the resulting file is a mp3. -
Not so much forgot as to have preferred alternatives for this sort of thing. Particularly when downsampling, having the ability to do some additional signal processing is often helpful, and for those sorts of tasks, Audacity is a very nice tool to have around.Originally Posted by Case
That said, iTunes is indeed a good recommendation for pure sample-rate conversion. And it's almost certainly on the poster's hard drive already.
DTS 15xx kbps to DTS 768 kbps and tsMuxeR question.
By Jared_ in forum AudioReplies: 0Last Post: 1st Jun 2009, 10:46 -
128 kbps to 96 kbps MP3 - big difference?
By joshua4 in forum AudioReplies: 12Last Post: 24th Oct 2008, 15:11 -
why 320 kbps mp3 have less vol compare to 128 kbps files?
By sumeshkri in forum AudioReplies: 4Last Post: 27th Sep 2008, 08:57 -
iPod classic limit for AAC NOT 160 kbps! Supports 320 kbps!
By FallenAngelII in forum AudioReplies: 1Last Post: 29th Dec 2007, 13:14 -
Convert .ac3 (384 Kbps) to Dolby 5.1 (448 Kbps) ????
By christopheramos in forum AudioReplies: 6Last Post: 11th Jul 2007, 01:35
